Who makes this kind of brake kit.
Old Jan 14, 2003 | 08:55 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
I would like to know if anyone makes a front brake kit that includes: A new set of improved/bigger calipers, larger cross drilled/slotted rotors, braided brake lines, with or without premium pads. I know about 1LE but didn't want to change out spindals if possible.
Old Jan 14, 2003 | 10:38 PM
laiky's Avatar
baer and stainless steel brakes
Old Jan 15, 2003 | 06:03 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i think you are going to have to change spindles with any of the brake upgrades. i know baers kit includes new spindles.
Old Jan 15, 2003 | 10:59 AM
Road Tech's Avatar
http://207.53.239.181/~terry/Wilwood-brakes/
this is a kit i am having brackets made for..
Old Jan 15, 2003 | 02:45 PM
JERRYWHO's Avatar
I made this kit from parts, But the people who make the parts will not make a kit for third gens.
Jerry
Old Jan 15, 2003 | 02:47 PM
JERRYWHO's Avatar
One more picture.
The bracket on top of the spindle is for the other side.
Jerry
Old Jan 15, 2003 | 07:16 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Nice looking setup Jerry . Got a couple questions if you don't mind . Which calipers are those? They look like the billet Superlight IIas but I'm not sure. Is that the hub they make for their light duty kit for thirdgens? And did you make that hat for that rotor? Last question (lol), is that a Wilwood rotor and what diameter is it?
Thanks,
Matt
(I'm working on putting together a similar kit with a friend)
Old Jan 15, 2003 | 08:12 PM
JERRYWHO's Avatar
Thanks,
Matt
Matt
The calipers are 1.75 piston billet NDL for .810 thick rotors.
This setup is for my 92 Z28 street-strip car so the light hubs will work for this, The hubs in the picture are new forged hubs not like the old cast ones people have used in the past.
The Hat is from a 57 Chevy kit for 8 bolt rotors.
The rotor is 12.19 X .810 thick and is larger than Baers street kit.
My next project is a 90 for road racing that will have Global west billet hubs, 6 piston calipers and 13.19 X 1.375 48 curved fin rotors.
Jerry
Old Jan 16, 2003 | 08:46 AM
german-motorsport's Avatar
We pushed the topic on how to get a "low cost brake" in several
postings way back (firechicken check our posts)
jerry nice systhem there!
in about 2 weeks we´ll get our 14 " (megapizza rotor ) with Monsterbrakes! Again thanks to saddam (this fu..) us costum is in delay cause they chek all stuff going out carefully!
The setup is a alcon from Baer with a 2 piece rotor!
In the pic a willwood set up we use at the track!
Jerry did you "just" put a bigger rotor on that ???
Of course with another adapter???
Somebody in here running a dual rear brake set (2 calipers)???
Old Jan 16, 2003 | 08:52 AM
For those you race , have money, need more than others or like cold summer nite races in Ventura (8 lane) Highways.
Old Jan 16, 2003 | 05:42 PM
CrazyHawaiian's Avatar
Car: too many ...
That last pic you posted with the 2 calipers, what caliper is that on the right upper side? It looks alot like the caliper on my Borg Warner 9 bolt rearend, but I dont know if its the good PBR caliper or if its the junk Iron caliper. Just wondering. Thanks!
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
novaderrik
Aug 10, 2015 12:44 PM
