Can a torque arm be boxed ?
Old Jan 18, 2003 | 07:18 PM
firebird305's Avatar
I just came from preston wilsons website (www.tpi305.com),And he list a boxed torque arm as a mod,Has anyone else done this?
Old Jan 18, 2003 | 07:48 PM
MdFormula350's Avatar
i never really heard of that. i would like to see one...
Old Jan 18, 2003 | 09:03 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
yea its possible to box a torque arm. Not the parts of course that go into the bushing and bolt to the rear end. But the part between the two sections can be boxed off.
Old Jan 19, 2003 | 12:55 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i had my bro box the stock torque arm on my car and used it for 2 years.it'll make it heavy tho. he went to extremes , i would think steel welded from top to bottom would help it. i live in illinois or i would give you mine.
Old Mar 25, 2003 | 03:32 AM
89ProchargedROC's Avatar
where in illinois do you live?
Old Mar 25, 2003 | 12:49 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
yes do tell where you live. i might want it.
Old Mar 25, 2003 | 06:49 PM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Axle/Gears: Moser/Strange 9"
i second the last post, i would be interested in it too. i live on the northside of chicago
Old Mar 26, 2003 | 07:09 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
mine isn't boxed, but I did reinforce it along with the panhard bar and LCA. Here take a lookPics
Old Mar 27, 2003 | 04:52 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Cool idea, Poncho! Did you notice any difference with those braces?
And as a side note.. how'd you protect the welds from rust? Did you use a weld-thru primer? I've got a MIG and want to hit my lower control arms and panhard rod, but am worried about having rust form "inside", and wind up with a control arm snapping in half from rusting out.
Old Mar 28, 2003 | 08:18 AM
Engine: 3.0
I just got these done, so I haven't installed them yet. Next I am removing the bushings and getting everything sandblasted. I then will paint/dip them in POR-15 to protect them from rust. My car doesn't see winter and barely sees rain so I am to worried...if you are though you can always spray in there with a rust protector like the stuff the use on cars at rust proofing centers.
I do expect to see a differnce, I was getting alot of wheel hop last year at the track.
Now all I need is to get some LCA relocation brackets and get everything installed....but I guess I need to get my car out of storage for that!!!
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
