Panhard Bar and Alignment
Old Jan 29, 2003 | 08:09 PM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
I'm planning on buying Spohn's adjustable panhard bar to re-center the rear after lowering. I'm assuming I'll have to have a front end alignment after installing it, am I correct ?
Gary
Old Jan 30, 2003 | 05:09 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
not just because you put a panhard rod in. if you are refering to the lowering springs, then yes you will need an alignment.
www.fl-thirdgen.org/frontspringswap.html
at the bottom i put the before and after differences when replacing the springs.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
