Warning about Spohn Torque arm...
Old Feb 3, 2003 | 04:23 AM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
if your car is slammed your gonna run into some problems with the arm. I recently swapped in a T56 and used the Spohn torque arm/crossmember. I have to say that they are very high quality. And that the parts helped out alot with performance. But I guess these parts were more designed for drag racing or cars with only a slight drop. My car is dropped 3" all around and the torque arm hit the driveshaft well. After some driving the problem was solved though as it dimpled in the floor pan. If my car only had a 1-2" drop this wouldnt have been a problem. So to all you others out there its all good and I suggest this part. As for the people who are slammed I suggest that you possibly dimple that section in the floor pan before installing the arm.
Old Feb 3, 2003 | 09:00 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Just curious, which part of the torque arm is hitting the floor pan?
Old Feb 3, 2003 | 09:47 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
thanks for the warning, i am going for the 3" drop very soon.
Old Feb 3, 2003 | 07:54 PM
CaysE's Avatar
Could we get some pictures of that? I plan to eventually have the same setup.
Old Feb 3, 2003 | 08:42 PM
SteveSpohn's Avatar
You're probably talking about the rear mounting bracket of the torque arm. You're correct, if your car is slammed, it wants to touch the floor pan in that area. What I do is crude, but it works, and that's to dent the floor pan at that area with a BFH.
Steve
Old Feb 3, 2003 | 10:52 PM
BORLAZ06's Avatar
AHAHAHAAAAAAAAAAAAAAA....you have the same problem too. I kept hearing a clunk after the installation of the torque arm. Stupid TA mount. What I did is I got a huge metal hammer and kept hammering away the tunnel area. After I did this there was no more clunk. So jus go under your car and start banging away like Steve said. LOL!
and if you keep hearing more noises its prolly the ebrake mount hitting your TA. I removed mine. Im thinkin of relocating it and making it function.
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
