changing springs help
Old Feb 4, 2003 | 03:23 PM
87irocz92vette's Avatar
can someone please tell me where i can info on how to change the rear springs ---stock to stock-? thanks
Old Feb 4, 2003 | 03:49 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Heres a nice and simple way to do it. Jack up the rear of the car and put it on jack stands letting the rear end drop down. Take off the shocks which will let the rear end drop down even more. You could also take off the sway bar endlinks which would drop it even more but hteres no need for that. Then go under the car and push up at the spring compressing it then pull it out. Then grab the new one and shove it in. Thats how I did it its pretty simple. It also helps if you have a friend push down on the wheel on teh side that your trying to take out. Which lowers the rear end more too.
Old Feb 4, 2003 | 05:31 PM
MdFormula350's Avatar
couldnt of said it better
the rears are easy, the fronts are a tad more difficult.
Old Feb 6, 2003 | 12:23 PM
aklaim's Avatar
Yeah the rears are way simple. I did mine on Sunday and it only took me 2 hours to do both springs and shocks. Gettting somebody to help push down on the rear definetly helps.
Old Feb 6, 2003 | 03:16 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You can get a bit more drop by taking the bottom of the rear shocks loose from the rearend and doing the same with the panhard rod.
Click the link in my sig for pics of a spring swap.
Ed
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
gixxer92
Sep 1, 2015 04:32 PM
johanlindgren
Aug 16, 2015 12:16 AM
