attnetion steve spohn
Old Feb 7, 2003 | 12:49 AM
black84-6spdz28's Avatar
i have your torque arm on my car for the t56....i am having some problems with it......
its making a clunking vibration when i slow down and i know that everything is tight..i was wondering if the problem is that the two sets of bolts where the torque arm bolts onto the crossmember
could this be caused by the top bolt being a little loose and the bottom bolt being tight?...the clunking is right by the shifter area right where thses bolts are...
i also checked the rear end bolts and they are tight also
any ideas?
Old Feb 7, 2003 | 02:43 AM
Dirk's Avatar
TGO Founder/Former Owner
Car: 1992 GTA
I have a similar sound! For me, I think it's the top bolt of the metal bar on the TA front mount pulling down onthe metal lines on the passenger side... kinda pulling them down and TWANG! letting them go and hitting the tunnel!
Old Feb 7, 2003 | 02:49 AM
this is when i let off the gas and it sorta "rocks" like there is play somewhere...its not a twang...its a clunk....but its in the same area
Old Feb 7, 2003 | 02:50 AM
BORLAZ06's Avatar
Re: attnetion steve spohn
my car was doin the same thing yesterday. it turned out to be the lower bolt on the front mount. it was loose...most likely cause i was running slicks tighten those two bolts again and you'll be fine. oh and use some loktite and dont grease those fittings. check for clearances all around too, to see if anything is hittin.
Old Feb 7, 2003 | 02:52 AM
looks like i gotta pull the drive shaft then...grrrrrrrrrrrrrrrr....damn driveshaft safety loop.....
the lower one is tight as hell...my guess the top one loosened up somehow or i never got it real tight....
Old Feb 7, 2003 | 02:54 AM
BORLAZ06's Avatar
oh you must have both front and rear loops. i have the same setup and i was forced to chop off the front loop.
Old Feb 7, 2003 | 02:55 AM
i have just the front loop......but i still need to yank the drveshaft to drop the cross member to get the ta down low enought to tighten that bolt
Old Feb 7, 2003 | 02:56 AM
BORLAZ06's Avatar
this must be ur problem..
i said good bye to it. the loop that is.
Old Feb 7, 2003 | 02:57 AM
i am wondering if that is the bolt that is loose...that top one...grrrrrrrrrrrr
Old Feb 11, 2003 | 12:23 AM
ttt:lala:
Old Feb 14, 2003 | 03:33 AM
ttt again
Old Feb 14, 2003 | 11:28 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I've had the same clunking problem since the day I installed the tranny. It's only when I let off the gas or cruise at a steady speed. I have yet to figure out what it is. Everything was torqued down really good, and I have the angle set to -1degrees like you're supposed to. I really don't think this problem is from a loose bolt, at least in my case. But I don't know, it's stumped me for some time now.
Old Feb 15, 2003 | 05:53 AM
EvilCartman's Avatar
Car: '82 Z28
I've got that same clunk but I'm running a spherical rod end instead of the bushing. Everything is good-n-tight but the arm still moves up and down ever so little due to the size difference of the bolt and the hole in the rod end.
Old Feb 15, 2003 | 09:37 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I just installed the same arm with the front loop. I havent actually driven the car yet, so I'm not 100% sure whats going to happen, but it looks like there is interference with the top tube of the torque arm and a bolt that holds on a bracket for the fuel lines. The arm itself looks great, and seems to be a very heavy duty piece, I'm just a little dissapointed in the fit Hopefully it dont cause too much of a problem.
Old Feb 19, 2003 | 12:28 AM
i wonder if i can relocate that bolt if thats it...
Old Feb 19, 2003 | 08:36 AM
Scott_92RS's Avatar
Car: 1992 RS
I took a look at my interference problem, and it looks like I can "persuede" that area with few pops of a hammer. The sheet metal in that area is pretty flimsy, and it looks like the bracket can be removed fairly easily.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
