Are there any STB's out there for carbed cars?
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Does anybody make one that goes around the air cleaner??
Eric
Eric
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
The one I found from Edelbrock says it's for a TBI car with the A/C on the passenger side. The TBI part will be the same as the carb, I know, but my A/C is on the driver side? Does anyone have one of these?
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I hope that's a loveseat in that picture and not a sofa; that bar looks freakin' long. How does it fit? Does it just go underneath the air cleaner? Do you know where I can get one of those?
Eric
Eric
I've got a Holley intake with a 700CFM double pumper 4-barrel on it and a 14"x3" summit air filter. I bought and installed the HPM-3260-AB
http://www.hpmotorsport.com/
It looks great and works awesome! Not a bad price either. the only mod I had to do was make a 1/2" spacer between the brace and the firewall (it was a 3-point brace).
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Thanks. Do you end up having to remove the STB then every time you want to work under the hood, or can you usually work around it?
I usually just work around it. It doesnt take up much room. I'd take a pic, but I just got my engine back in. I'll have it all back together in a couple weeks. the only time I would have to remove it is if I wanted to work around near the back of the engine, like by the distributor.
Car: '85 Z28
not my car, but here is a pic of the bar installed
It fits great on my car, goes over top the air cleaner. I don't think Jamex is still in business, bought mine used. You could probably find one on ebay
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I have an L69 dual snorkel air cleaner. I'm not sure though how much extra room there is though above the air cleaner in the T/A.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Car: 91' RS
Engine: Built 355
yeah....
That piece looks good and stiff, not to mention it'll clear pretty much any air cleaner setup by the looks of it!
I bought one from an outfit in Canada, www.flatoutperformance.net , It is en route and should show up any day now.
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
) but I checked and its gonna fit fine.
