Anyone with the kenny brown strut brace, please step inside...
Old Feb 19, 2003 | 09:50 AM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I'd like to know if your brace fit, or if it needed modification, and also what runners are on your engine. I'm thinking the problem is with the SLP runners, I'm just trying out my theory though.... thanks.
Old Feb 19, 2003 | 08:32 PM
Hg's Avatar
Hg
Car: '87 Z
nobody???
Old Feb 20, 2003 | 11:49 AM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
sorry wrong post
Old Feb 20, 2003 | 12:14 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
I have the stock intake and had to build two 3/8" spacers to give it enough clearance from my upper plenum.
Old Feb 20, 2003 | 01:49 PM
92GTA's Avatar
I had to build a spacer but on on the drivers side (so much for them being made in a jig), it's about 3/4 of and inch thick, sold aluminum cut to match and painted to match. Costed about $50. Now it clears my plenum by almost half and inch and I can close my hood just fine. Another guy on here with SLP runners had to do almost the same and he helped me out when I first got the brace...
Old Feb 21, 2003 | 06:09 PM
Breadfan's Avatar
That kenny brown brace was junk . It one hit on my brake lines , it was 1/4 to far from my firewall . And didnt' fit correctly by my upper strut mounts . I called kenny brown , they told me my frame was bent , but hard to beleave seeing my car hasn't been wrecked.
Old Feb 23, 2003 | 07:21 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
strut tower
I had to put one on my car after i installed my tubeular k member. front end felt like a wet knoodle. No fit problems though i have a mini ram
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tattmann
Sep 27, 2015 05:20 PM
