performance suspension
Engine: 305 tbi=LO3
Transmission: Automatic
ok, i have an 88 ta that has the performance suspension. i just replaced the rear sway bar mounts and bushings. that bar had a 1" diameter. does anyone know offhand what dia. the front sway bar is? i looked and the bushings the other day and they are worse than the ones on the back were.
-mike
-mike
Engine: 305 tbi=LO3
im asking because the auto parts people in my area are kind of daft. and i dont trust them when i get the bushings/mounts
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
You don't need a micrometer. Just get a cheap slide caliper and measure them first. You can get one from a hardware for under $8. Your swaybar if original should be metric. I'd guess that an '88 T/A with a WS6 suspension would have either a 34mm or 36mm front swaybar.
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Most parts stores have a mic or a caliper behind the counter that you can borrow; then you don't even have to buy one. Remember to check it right in the middle of the bar though, not towards the end where the bar is slightly flattened.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
