sway bar bushing size?
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
You need to physical measure the diameter of your swaybars. Even a cheap plastic caliper will do. WS6 does not translate into a certain size swaybar.
Car: 1986 Firebird
Engine: 2.8 V6
If you don't have calipers, you can snug down an open ended adjustable wrench down on the center of the front bar. If you need to (and try not to!), loosen the wrench just enough to slide it off the sway bar. Now measure the jaw gap with a metric ruler. I'm betting you've got a 32mm front bar... but don't quote me!! Check it for yourself...
Linson
Sep 21, 2015 01:08 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
