Steering wheel installation problem
Old Feb 26, 2003 | 04:02 PM
mpitts77's Avatar
I hope this is the right forum =D
Anyway I kinda..broke the C ring thats on the steering wheel column..the one before the canceling cam. Anyone know the correct size of this C ring..or a part number?
Alson I replaced the power window motor..and i'm haveing trouble getting the tracks back in...anyone know of a site that shows one in..or some hints about putting it back in?
Thanks,
Michael
1992 Camaro RS
L03 with TH350
Borla exhaust
leaking rear hatch =/
Old Feb 26, 2003 | 06:06 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You mean that damned impossible-to-remove lock ring? It's probably a dealer part... just had to change the ignition switch on my car this past Friday. That lock ring was a pain. Finally got the idea to use my set of picks on it to get it off the column.
I assume the dealer can get one; it's a pretty common part across all their car lines.
Old Feb 26, 2003 | 08:14 PM
mpitts77's Avatar
Nah it's the one right before it..it looks like a lockign ring but it has those 2 holes that use a tool to remove it....wish i had my camera on me =/
Old Mar 2, 2003 | 01:57 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
you mean a snap ring
Old Mar 2, 2003 | 01:59 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
theres snap ring pliers that go into the holes and open it up. most tool places have em.
Old Mar 2, 2003 | 08:17 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh; that one, my bad. Yours had the holes for the pliers? Mine was some kinda oddball shaped triangular ring; completely threw me off. (And I have snap ring pliers, too.) Wound up using a set of needle nose pliers on 'em- I opened up the needle nose pliers, which expanded the ring.
With the window; you took out the tracks, or just the regulator itself? Hopefully just the regulator; the tracks will be a nightmare to adjust (to get your window aligned again).
Old Mar 3, 2003 | 08:09 AM
mpitts77's Avatar
Well I got everything put back together and working. Thanks for the info guys.
Next up..trans mount....and hatch alignment..
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
