is the torque arm supposed to be loose at the rear end?
Old Mar 1, 2003 | 11:30 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
i got a '94 formula parts car that was wrecked. it rolled and looks like it landed upside down on its trunk, the rear end looks like it didn't get hit. i removed the front torque arm mount today and noticed that the arm was loose where the two bolts go through it at the rear end. i could see the bolts moving around even though the nuts were tight. is it supposed to do this or is something broken? i'll probably pull the arm completely off tomorrow but i just wanted a heads up.
Attached Thumbnails is the torque arm supposed to be loose at the rear end?-pastedimage.jpg
Old Mar 2, 2003 | 02:01 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
torque arm should be torqued (Pun intended) to the rear end somewhere close to 100Lbs- Id have to look it up for the correct tq spec- but anyway there should be no play or movement between the torque arm and the rearend at all. Bolts also always install from the top down- in case a nut comes loose the bolt will not fall out this way.
Old Mar 2, 2003 | 06:25 AM
ede's Avatar
ede
even without bolts the torque arm is fairly snug aginst the mateing surfaces on the rear.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
novaderrik
Aug 10, 2015 12:44 PM
