torque arm or LCA's and relocation brackets
Old Mar 2, 2003 | 01:28 AM
midnightcamaro's Avatar
which one would be the best first to do. i want to go with a torque arm that goes to a crossmemeber i dont want a trans mounted torque arm would i get more out of the torque arm or the LCA's and relocation brackets? which one 1st thanks.
Old Mar 2, 2003 | 01:55 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
If wheel hop is not an imediate problem then I would suggest the torque arm first. Why?- because it is much more expensive- after you save up and buy that then the relocation brackets will follow soon because they are alot less expensive.
Thats always my method- buy the expensive things first, then you're committed and the cheaper things will follow.
Old Mar 2, 2003 | 06:18 PM
sllt1776's Avatar
Car: 89 Iroc-Z
i would go with the relocaion brackets and the arms first. especially if your car is lowered, to regain the correct suspension geometry. i would get sub-frame connectors first if you don't have them, even though that's not what you asked.
Old Mar 2, 2003 | 07:41 PM
BORLAZ06's Avatar
Re: torque arm or LCA's and relocation brackets
if your car aint lowered and u see that ur lower control arms are in the correct geometry than id get the torque arm; then get the LCA brackets. the lca brackets alone, you'll be able to feel a difference in traction.
Old Mar 3, 2003 | 10:32 PM
thanks for the opinions guys also can i use the relocation brackets with the factory LCA's. if so then i can just bolt the other ones in later right? thanks for the help
Old Mar 3, 2003 | 10:38 PM
MdFormula350's Avatar
yes you can use the relocation brackets with the stock lca's.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
luvofjah
Sep 10, 2015 10:41 AM
