Poly. bushings
Old Mar 5, 2003 | 09:00 PM
KMAN's Avatar
Poly. bushings
How difficult is the instalation for a novice? i was looking at the kit that spohn offers. thanks
Old Mar 6, 2003 | 12:58 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Welcome aboard....
It really depends on which bushings you are doing. I had my A-arm bushings done by a shop but I did everything else myself. If you are the least bit mechanically inclined, do them yourself. It'll save you money. Click the link in my sig to see some of the basics like a tranny mount and torque arm bushing replacement. I will be replacing the A-arm bushings in my RS soon and I will be doing them myself this time and will do another picture how-to on those. Someone replaced theirs using a ball joint press from Auto Zone and made it look easy, so I'm gonna try it. The A-arm bushings will be the hardest to do, all others are unbolt and reinstall basically.
HTH....Ed
Old Mar 6, 2003 | 01:28 AM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
Hey Ed I'm about to install new KYB struts/shocks on my car next week as well as a spindle that bent from an accident i had. Is it possible to remove the ball joints without damaging them so that they can be reused? or should i just look into buying new ones before i do the suspension swap
Old Mar 6, 2003 | 01:56 AM
ebmiller88's Avatar
If you want to reuse them, just leave them in. You don't HAVE to take them out. If you want to pull 'em out, use a press and they will be fine.
However, if you had a wreck that bent your spindle, I'd at least replace that one...so therefore why not do both?
Ed
Old Mar 6, 2003 | 10:51 AM
KMAN's Avatar
ive alredy done the tranny mount, and it was redicously easy. if the rest are anything like that it should be cake then. thanks
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
camaro1185
Oct 26, 2015 06:51 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
