was just wondering stock ride heights so i can measure my new springs and see the difference in numbers, i can see its lower by eye but not as low as the springs said it would be, i do know it handles a helluva lot better
i think that mine is aobut 4.5 inches off the ground. from what i understand from others on this board, the springs have to "settle in" before it will be as low as they claim. not sure if there is any truth to this or not though
i know they have to settle,l i can see it gettin lower as the days go buy,
i found some 1.5 inch drop shocks to go with it if i wanted to but ill wait a couple weeks and see whats up with them
so 4.5 hmm ill have to measure it tomarrow and see where it is!
My stock 83TA (WS6 for that year - whatever that means for an 83) is 26.5 inches from the front fender lip to the ground and 28 inches at the rear.
Has a 100 miles on the springs so its probably sagged a bit.
Wishmaster's87IROC
close
- Join DateFeb 2000
- LocationWinston salem, NC
- iTrader Positive Feedback100
- iTrader Feedback Score(4)
- Car1987 1SICIROC.....1999 TransAm
- Engine385 HSR.....LS1
- Transmission700R4 with Midwest 3400 2.4str...M6
- Axle/GearsSLP Zexel Posi unit 3.42's...3.73's
- Liked:0 Times in 0 Posts
What are your measurements nowafter the spring install? what springs did you install?
the new springs r drop zone 1.75" drop springs
from the center of the front fender well to the ground its 26.5"
and from the rear its 27"
there have only been on since 03/09/03!
Wishmaster's87IROC
close
- Join DateFeb 2000
I have the same springs. Ive also got the same measurments as you do but mine have been on since early Feb but I havent driven the car that much. I got an instant 3/4 all the way around from stock measurements. Someone on here told me that all springs need to settle and will drop more. Personally I dont see getting an aditional 3/4 in the back and another 1" in the front but you never know... I will be happy with atleast another 1/2 all the way around.
I do need to take my front springs out and re-index them cause if they are not right that will cause them to sit higher than what they should be. Also the rears too. Just from what Ive read in here.
im just glad, its sitting lower! my freinds saw it and some were like, is there somthing diff with your car? the wheel actually looks good on it now!, i said yeah i dropt it sp the 15 actually looks good! im thinking about getting some of the replica IROC's in 17x8's to fill that whole gap!
