Energy suspension worth the money??
Old Mar 11, 2003 | 03:13 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
i am in the process of putting ball joints on my 92 firebird and my sway bar bushings were pretty worn out and i was wondering if it is worth the extra money to buy the polyurethane bushings or just use rubber ones
Old Mar 11, 2003 | 04:25 PM
aklaim's Avatar
Get poly bushings. They will last much longer than stock rubber and have less deflection then rubber. Poly graphite is another option. It supposedly gets rid of the squeaks associated with plain poly. I believe Prothane makes poly graphite bushings.
Old Mar 11, 2003 | 08:25 PM
Engine: LO3 and LT1
do they actually make a diference in the handling at all
Old Mar 12, 2003 | 04:03 AM
JPrevost's Avatar
Car: 91 Red Sled
Yes, they're great. Just make sure you lube them up or they won't last as long as rubber. I've had a couple go loose on me and cause rattles. 20k miles and it was time to replace. Lube em up and they're great.
Old Mar 12, 2003 | 07:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I like ES (note my sig). However, you might consider the greaseables from Top Down or Spohn and avoid the squeak business altogether.
JamesC
Old Mar 12, 2003 | 03:09 PM
Engine: LO3 and LT1
what should i use to lube them it says do not grease on the package for the endlinks
Old Mar 13, 2003 | 01:55 AM
JPrevost's Avatar
Car: 91 Red Sled
Endlinks don't see the same friction forces. They only see compression. If they're squeeking then you need a new suspension or a new car. Any type of grease seems to work. Probably go with the silicon based stuff. Lithium grease could work but it's too thin, get the thick stuff.
Old Mar 13, 2003 | 12:27 PM
aklaim's Avatar
Correct me if I'm wrong but endlinks don't require greasing. I have never in my life greased a set of endlinks and have run into zero problems doing so.
Old Mar 13, 2003 | 03:55 PM
Engine: LO3 and LT1
thats the only part that i bought energy suspension thats why i was wonderin when they said greasing i only had to put them on because i broke them when i was takin the front apart to change the ball joints
Old Mar 14, 2003 | 09:57 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
here is a helpful hint i found out the hard way dont buy the master kit from energy suspension. you do not get what you pay for. you will either save money or get more for what you pay for if you piece it together.
Old Mar 14, 2003 | 10:46 PM
Engine: LO3 and LT1
its amazing how they get away with that isnt it
Old Mar 15, 2003 | 02:40 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yeah, don't lube up the end links. Use Formula 5 lube which is what they give you with bushings or get a big tube of the sticky stuff from Spohn, I grease everything up with that stuff.
And yes, ES or other brands of poly bushings are definitely worth it. You can buy rubber parts but for a buck or 2 more, get the good stuff.
Ed
Old Mar 20, 2003 | 09:16 AM
Dr G's Avatar
JPrevost "Yes, they're great. Just make sure you lube them up or they won't last as long as rubber. I've had a couple go loose on me and cause rattles. 20k miles and it was time to replace. Lube em up and they're great."
I have poly bushings throughout on my GTA which were installed by the previous owner ~20K ago. Should I plan on replacing these routinely or onyl when they perish?
How often should you lube them?
Gordon
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
