82 Trans Am upgrades.
Old Mar 21, 2003 | 05:21 PM
82tiresmoker's Avatar
Car: 82 Trans Am
Engine: 305 4bbl
Transmission: 4 spd
Planning a 400ci engine swap into my 82 Ta and need to get some opinions on what to do about the suspension. As far as I can tell its stock and that won't work very well with a 400 in the car. I plan on using it as a street car only, and would like to get the thing to handle half decently. I remeber reading somewhere that the 87 and newer cars have a much better suspension setup. Is this true? and if so can I swap it all over to my car? Currently I have drum brakes in the back, so I'd like to swap to disks, will a later year 3rd gen rear end be able to handle the power that i'll be putting to it? What about a 4th gen rear? Should I just forget the later suspension and buy everything aftermarket? Sorry for so many ?'s, thanks guys
Old Mar 22, 2003 | 11:15 AM
MdFormula350's Avatar
well i would think you need subframe connectors, then as far as a read end goes most likely try to find a 1989 + rear end from a thirdgen. a 10 bolt with disk brakes and posi with 3.23 gears would be a good start, but a built up 9 bolt would be even better..
i guess it depends on what kinda power you are going to make with the 400 engine...
Old Mar 22, 2003 | 08:18 PM
Car: 82 Trans Am
Engine: 305 4bbl
Transmission: 4 spd
I'd like to get around 400hp.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
