Question about brake light
Old Mar 21, 2003 | 09:18 PM
camarochic's Avatar
Car: 86 Camaro Iroc-z, 86 Corvette
Engine: 350 TPI Camaro, 350 tpi Corvette
Hey, I have a stupid Question for any one who knows. What Does it mean When Brake light on The dash is on?
I have no brake pressure And I just replaced the front brakes.
Also if you need this I have an 86 camaro vin code F.....
Thanks :lala: Thanks
Old Mar 21, 2003 | 09:40 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
the brake light comes on for two general reasons, the parking brake is on, or the switch in the proportioning valve has (or had, may be stuck) lower(or no) pressure on one side than the other, usally a leak in the system some where or air in the system(it could also be an electrical prob in the wiring to the light, but that is an entirlly different situation)
you said you have no brake pressure, what exactly do you mean?
does the pedal go to the floor?
if not, does the car stop/slow down when driving and appling brakes?
Old Mar 22, 2003 | 10:18 PM
rumpilstiltskin's Avatar
The exact same thing happened to me today for thr first time. The pedal would go to the floor, you'd stop but not near as fast as usual. When i got home i noticed a puddle of brake fluid under the front of the car. Any ideas where it was coming from? It was on the drivers side.
Old Mar 22, 2003 | 11:30 PM
Spdfrk1990's Avatar
check ur master cylinder and your driver brake hose.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
