Uneven brake pressure...
Old Apr 2, 2003 | 12:44 PM
jc92formula's Avatar
Hey guys, what would cause my car to pull to the left when the brakes are applied? Obviously, the left wheel is braking harder or sooner than the right... right? Any suggestions would be helpful!
1992 formula
4wheel disk brakes
Old Apr 2, 2003 | 02:30 PM
trace's Avatar
also could be the ball joint
Old Apr 2, 2003 | 08:53 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
brakes could need to be bled or you could have a pinched brake line, i had the same problem like a year ago, mine turned out it was a pinched passenger front break line, so it made mine pull to the drivers side when i hit the brakes
Old Apr 3, 2003 | 09:50 AM
Thanks guys, I'll check those lines!
Old Apr 3, 2003 | 03:11 PM
MdFormula350's Avatar
yeah my guess is the line also..
Old Apr 5, 2003 | 03:12 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
if its pulling to left then it means left is getting more pressure so you should check pass side for restriction and might as well check tie rod ends also while your under there, that can be a cause too.
Old Apr 9, 2003 | 02:57 PM
alm396's Avatar
99% of the time a brake pull to one direction indicates a problem with the front on the opposite side of the pull. If your pulling left I would be looking at the right brake hose for collapse or a bad or sticking right front caliper. Try bleeding that side and see if fluid flow from the bleeder looks to be of normal volume. Any restriction of fluid flow or caliper issues will cause the pull you are describing.... ALM
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
