Can Someone tell me exactly what these things are and where they mount?
Old Apr 4, 2003 | 09:23 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
They are called e.t. improvers from TDS here on the boards.
I don't really see where they mount etc.
Here's a pic:
Attached Thumbnails Can Someone tell me exactly what these things are and where they mount?-201210.jpg
Old Apr 4, 2003 | 09:50 PM
KenV's Avatar
Car: A few
Engine: All Eights
Transmission: All kinds
Under the left front swaybar mount...
...the ad says you need a functional front swaybar and that the plates only go on the left side. Judging from the notches I would be comfy saying that they go between the swaybar bushing and the front crossmember on the driver's side.
Check out the "similar items" on the page with that part. I believe the plates mount under the bushing housings pictured.
HTH, peace
K
PS Asking Lon Salgren himself wouldn't hurt. He's the TDS boss, and a real good guy.
Old Apr 4, 2003 | 10:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They lower the front sway bar, so that when the front end raises up at launch, the sway bar won't limit the control arms' downward travel so much. Lets the strut all the way out etc.
Old Apr 5, 2003 | 01:23 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Oh g0d, we need to keep them off of RB and limit his travel if possible- Partner, sorry but you give bad info.
Et improver plates in essence do the same thing as what air bags installed on the rear do- what's that? they allow a slight weight jack to one side so when engine torque/twist is applied to the chassis the car will launch more evenly planted- The car stagnant will favor (lean to) the opposite side of thrust twist. When under power it will sit more level and planted for traction.
I'm sure RB will try to defend himself and say what a rude person I am- fact is- this is a tech board and people rely on accurate info- and you cowboy toss things to the wind. People don't like to be mislead and spend their money wrongly.
Old Apr 5, 2003 | 08:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Old Apr 5, 2003 | 12:00 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
do they hurt handling?
Old Apr 5, 2003 | 03:05 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Yes, they are only for straight line drag.
Old Apr 5, 2003 | 08:12 PM
Mark W. Winning's Avatar
In which case you would just ditch the sway bar away, so why us them?
Old Apr 5, 2003 | 08:36 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
In my explaination above I explain how TDS's ET Improver plate make use of a front swaybar as a weight jacker. If you remove it entirely then you loose this option. Cars with airbag rear setups don't need the front bar at all but if you're not setup with airbags then TDS gives you a nice inexpensive helper kit that will in essence cheat and give you close to the same results.
Orr89RocZ
Apr 25, 2016 08:28 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Bob88GTA
Aug 18, 2015 03:31 PM
sreZ28
Aug 14, 2015 07:48 PM
