1LE rotors
Old Apr 7, 2003 | 01:26 AM
Murt TTA's Avatar
Car: 89 TTA
Engine: 3.8L turbo
Transmission: 200r4
1LE rotors
Is anybody running cross drilled front or slotted 1LE rotors? Any improvement over the stock 1LE's or just for looks? I have performance friction pads right now, they seem to be a pretty good all around pad.
Thanks,
Murt
Old Apr 7, 2003 | 03:06 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
I have slotted baers.. even they tell you that they are mainly for cosmetics.. if you do some severe duty driving then they help for it is to aid in the outgassing of brake pads which can cause the pads to lose contact somewhat from the rotors..
Crossdrilling is a bit controversial because the chances of the rotor cracking is higher with the holes.. I have seen cracked drilled rotors, not a pretty sight.. but that is only under extreme conditions usually, if you drive that hard you should have the money for new rotors..
best bet for the money is to slot and zinc wash, but there are probably other opinions out there
Old Apr 7, 2003 | 01:35 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
I have em, now i just gotta get a car to put em on. then i'll let ya know.
Old Apr 7, 2003 | 03:32 PM
Kandied91z's Avatar
who makes a 1-le slotted/crossdrilled option?
i have the gm parts version for stock disc brakes on the car that i removed when i put the baers on.
the difference with the zinc coating that is on the eradispeed rotors is night and day.
here is a pic of the gm version after sitting for less then a week with limited use.
Kandied91z's Avatar
here is a pic of the zinc coating with the same amount of time. both are basically brand new granted the gm setup had about 150 miles more between the two. i'd definately get them coated if they don't come that way on whatever you choose, but it is costly.
Attached Thumbnails 1LE rotors-jeffs-baer-brakes-behind
Old Apr 8, 2003 | 01:14 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Fronts:
Rears:
Old Apr 8, 2003 | 03:56 PM
Kandied91z's Avatar
so where did you get them? are they a gm part or aftermarket?
Old Apr 8, 2003 | 06:39 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Aftermarket, Autozone, they said slotted, they were really slotted and drilled.
Old Apr 8, 2003 | 08:34 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Cryo and Slotted with Stage II pads from Praise Dyno Brake:
Old Apr 8, 2003 | 09:40 PM
87IROC350's Avatar
Engine: 5.7
I have the same ones as Z28*****. Got them from autozone crossdrilled and slotted.
I installed the 1LE brakes front & rear about a month ago with Green stuff break pads and braided lines. The thing will throw you through the front window it stops so hard. No comparison to the stock brakes.
I was very pleased with the results. Unfortunately I can not give you a before and after with the slotted/drilled rotors.
Old Apr 9, 2003 | 01:15 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
87IROC your gonna have to come over to thirdgenparts and let me take a look at your car PM me sometime, or if you have aim my s/n is the same as here.
Fanatic1074
Oct 3, 2022 05:57 AM
loud91rs
Oct 5, 2015 10:05 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
the_hamturdler
Sep 22, 2015 02:59 AM
