steering wheel shake
Old Apr 8, 2003 | 07:26 PM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
I got steering wheel shake like a ****. It wants to throw me out the window at around 35 miles an hour. What do you think the problem mostlikely is. Tierod, mis allignment? I am thinking about redoing the whole front end but I dont know what brand would be best for drag/some street applictions. Anyone with any comments, please post.
Old Apr 9, 2003 | 08:05 AM
82camaro's Avatar
Car: 82 camaro SC
At that slow of a speed, my first guess is bad tire/bent wheel/loose wheel.
Old Apr 9, 2003 | 08:14 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Separated tire
Old Apr 9, 2003 | 06:30 PM
bubafett's Avatar
Bad tire
Old Apr 9, 2003 | 07:07 PM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
as in bad tire the tire itself or the wheel bearings, because after inspecting it just now it rattles a bit when i shake the tire of jacks. -
Old Apr 9, 2003 | 07:42 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
the tire itself,
if you run your hand along the tread of the tire (in the air), you may need to slowly rotate the wheel, you should feel a spot where the tread goes all wierd(not flat), across the tread (side to side , from the inside to the outside)will be a high spot and a lot spot,
I'd almost bet this is your problem
83 Crossfire TA
Jan 3, 2016 01:26 PM
Amillionoh7
Sep 5, 2015 11:44 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
