Tips for Adjusting LCAs
Old Apr 10, 2003 | 12:43 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
I just purchased some adjutable LCAs to fix a problem with my rear not being centered fore/aft on the passenger side. Does anyone have any tips for adjusting the new ones so that everything is square, or performance tips for adjusting the rear for the best handling?
Old Apr 10, 2003 | 08:08 PM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
I just purchased Lakewood traction/lift bars. I also wanted some advise on adjusting them.
Old Apr 10, 2003 | 11:42 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Just center one side in the wheelwell (center spring into can area mainly so nothing rubs) then make sure the other side has the identical measurement from eyehole to eyehole. Any alignment adjustment for a tweaked unibody would have to be adjusted on an alignment rack, so just set them equal for your best bet and have an alignment done if things feel like they are driving sideways(rear steering to one side or the other while going straight). This is rare unless car has been bent.
Old Apr 11, 2003 | 07:28 PM
82camaro's Avatar
Car: 82 camaro SC
Get em' so they look about right, and have someone follow you on a nice flat road. Have the 'follower' check for dog-trackin'--rear tires aren't directly behind the front tires. To do it correctly, have an alignment shop can set the rear axle straight. The adjustability isn't for looks, IMO.
Old Apr 11, 2003 | 07:34 PM
82camaro's Avatar
Car: 82 camaro SC
double post...
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Jorlain
Oct 8, 2015 01:57 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
