gear swap question
Old Apr 11, 2003 | 09:51 AM
MotorCityMuscle's Avatar
gear swap question
I currently have a 2.73 open diff rear in my 86 IROC. Im interested in adding a set of take off 3.42 gears and Zexel posi from SLP. I think I'll need a different carrier as well? Basically, what all will I need to do the gear swap, aside from the gears and posi unit?
Thanks in advance,
Dave
Old Apr 11, 2003 | 10:23 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
if its an 86 you will need new axles from a 90+ that are 28 spline.
you might be better off picking up a 3.42 rear from a 90+ v6, and then putting in the slp take off carrier.
Old Apr 11, 2003 | 01:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The posi is the carrier.
You will definitely need axles to do it that way. Dewey is right; especially if you have drum brakes (all the 6-cyl cars do), you'll come out cheaper just buying a 3.42 6-cyl rear that already has the right axles and gears, and sticking the SLP unit in there, and swapping the whole thing into your car.
InfinityShade
Aug 22, 2015 08:00 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
mizz0313
Aug 12, 2015 06:45 AM
