Car pulls left slightly-rear brakes the cause?
Old Apr 11, 2003 | 05:01 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
My car has a slight pull to the left so after checking that the lines had not collapsed I thought that maybe one of the front calipers was seizing slightly. Not so, well at least when the brakes are cold. However, tonight I felt the rear drums after being out for a drive. The pass side was warm to the touch but the drivers was scorching hot. I'm not guessing that the driver side rear drum is not ajusted correctly and it is this that is causing my pull to the left?
I had always associated pull with the front brakes and never thought about the rears causing the problem.
Opinions please.
Robert
Old Apr 11, 2003 | 05:13 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
I've been having similar strange experience with braking. It pulls to left also, but feels like sometimes its actually the rear moving to the right causing front to move to left.
How do the rubber boots look on your pistons?
Pull your pistons out to see if any of the chrome is rusted over.
If its the rear, maybe a suspension prob (i.e maybe need boxed in LCA's or tubular).
I just redid my brakes about a month ago (front disk rear drum). I'm going to completely drain, and fill the entire system w/ synth brake fluid. The fluid naturally absorbs moisture and *** knows when the last time it was drained/filled. At this point, I guess it could be several things, but I think fluid and bleeding is a good place to start.
Old Apr 11, 2003 | 05:17 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Rubber boots on the piston looks good. I checked it and gave it a squirt of WD40 to make sure it was moving freely.
Old Apr 12, 2003 | 10:19 AM
Spdfrk1990's Avatar
like you said the driver side drum prob isnt adjusting right.
Old Apr 12, 2003 | 11:32 AM
did you really have to force that driver side drum over the shoes? Maybe pull it back off and adjust that little star wheel back until you get a little less contact. I hate drum brakes.
Old Apr 13, 2003 | 02:11 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Matthew,
Yes, the drivers side was really tough to get back on. I'll pull it off tomorrow and adjust it. This was my first time of ever messing with the drum brakes. I'll be getting discs in the future as drums are just a pain.
Thanks everyone. I'll update when I adjust something.
Robert
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
