Bad Brake Hose?
Bad Brake Hose?
My right front brake sticks a little bit and when you hit the brakes the car dives to the left. I put a new caliper on the rt side to no avail. I think it is a collapsed hose on the rt side. Just checking to see if this is what you guys think. Thanks
Scott
Scott
Scott, It definitely sounds like it could be a collapsed hose on the right side. I had the same problem and it was the hose.
DJP87Z28 and Frik92RS are right about replacing with SS braided lines. If you are going to the trouble of replacing a line and changing the brake fluid then why not upgrade them.
The difference in pedal feel when I put on Earls (EAR-28A190) kit was well worth it. Far more reassuring.
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I also put earls lines on my car and couldn't be happier with them.
Here is a link to a thread about the lines.
https://www.thirdgen.org/techbb2/sho...ight=hyperfirm
1992 Trans Am
May 10, 2023 07:19 PM
