what is the advantage?
Old Apr 14, 2003 | 12:09 PM
400 SB Iroc-Z's Avatar
What is the advantage of getting aftermarket Lower control arms. Are they worth the $200? I get really bad wheel hop and it is really annoying. With LCA relocation brackets would it eliminate that problem?
Old Apr 14, 2003 | 12:33 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
From what I know, you should get the trailing arms with the relocation brackets. I did the same thing on my car in addition to new shocks, a panhard bar, and new springs. I had really bad wheel hop before all this and now there is none.
Old Apr 14, 2003 | 12:50 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
They are stronger and have better bushing options.
I would try using the LCA relocation brackets first. It is less expensive and is part of the answer to the problem that you are having. Stock LCA's will work with the relocation brackets.
-Schultzy
djmarch
Oct 2, 2015 10:41 PM
age
Aftermarket Product Review
Dec 5, 2001 06:20 PM
RMK
Mar 26, 2001 07:46 PM
mostafa3k
Mar 19, 2001 10:40 PM
496Monte
Jul 24, 2000 10:03 AM
