anyone know spohn torque specs?
Old Apr 17, 2003 | 10:43 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
hey i just got my new parts from spohn (sway bars, wonderbar, and control arms), but my dad decided to throw away the install sheet with all the torque specs so i basically need specs for everything.. should i just use my stock specs or are they different for the poly bushings?
Old Apr 17, 2003 | 11:06 AM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
I just put the Spohn adj LCAs on my car and the sheet says 72 ft/lbs dry and 55 ft/lbs lubed. But I usually use the tight as I can get it rule myslef
Old Apr 17, 2003 | 11:27 AM
89RsPower!'s Avatar
thanks! i put the sway bars and the steering brace in and just used the factory specs for now and i cant believe the handling difference.. cant wait 2 put the control arms on but it just started raining
Old Apr 17, 2003 | 11:54 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
where in jersey are you?
im up north, bergen county.
Old Apr 17, 2003 | 12:45 PM
89RsPower!'s Avatar
hamilton, sorta between trenton n princeton
Old Apr 17, 2003 | 01:02 PM
89RsPower!'s Avatar
any body know the proper specs for the sway bars?
no green
Jan 9, 2016 09:22 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
