FYI...Front Brakes CLACK when peddle pressed
Car: 1988 IROC
Engine: 5.7 HO TPI
Transmission: 4 spd Auto
I had an annoying little CLACK sound that would come from both front rotors when I would step on the pedal. After dismantling them to repack the bearings and inspect the pads, I discovered the following: Pads were 80%, and installed properly. I repacked the bearings, and put it all back together. In the Chiltons manual it shows that you need to put a small amount of grease on the calipers, where the two prongs toward the front meet the mounting bracket part they bolt up to. There is always a very small gap there, and if you wiggle the caliper, it will move ever so slightly. So when you step on the brakes, the caliper moves forward about a 16th of an inch, and CLICKS agains the mounting bracket assembly. You will be able to see the shiny wear spot when you take it apart. I installed grease in the appropriate place, and the CLICKING noise is now gone. This is just an FYI post for anyone with the same problem.
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
It will be back. At least mine did. I put that grease crap on last time i did my pads and two weeks later they were noisy again.
Car: 1988 IROC
Engine: 5.7 HO TPI
Yes, I used bearing grease, it has been about 4 weeks now and the annoying sound has not returned. Just one of those little things that is easy to overlook !!
dbrochard
Sep 19, 2015 08:13 PM
MikkoV
Sep 9, 2015 04:25 PM
