where can i find a cheap set of rear calipers?
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i wanna good set of stock ones.....cuz since i've had the car it hasnt had rear brakes and now that i've had to get the rotors turned and put 2 sets of pads up front i believe taht i should try and get the rears working...........i've already replaced the master cylinder,proportioning valve, etc...
Car: 04 Xtreme Blazer
Engine: 4.3L V6
https://www.thirdgen.org/techbb2/sho...threadid=78725
the recall covers the 82 - 88 rear disk manual trans cars, but the same brakes are on the auto cars , same kit fixes both, and if you get new (reman) calipers from an auto chain, they will likely NOT have the recal parts installed
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
