Weird Vibration After Hard Braking
Old Apr 18, 2003 | 04:49 PM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
Here is the problem. After medium to hard braking and coming to a full stop I feel and hear this weird vibration. If I slow down very gradually and come to a stop it won't do it.
If it is happening and I let off the brake and roll a few inches then stop again the vibration remains.
However, when it happens and I shift into neutral it stops imediately. If I then shift it back into drive the vibration is still gone. I really don't know what is causing the problem. Any ideas?
Old Apr 18, 2003 | 10:18 PM
BOTTLEDZ28's Avatar
Transmission: A4
check for loose or worn out idler arm. my cars front end shakes vilentoy once in while if I make a panic stop. I am 90% sure its my idler arm. its so worm out. Check for any loose or worn out suspoension componets in the front. cehck for a broken belt in one of the tires, makes sure your tires are balenced too
Old Apr 19, 2003 | 11:40 AM
Max's Avatar
Max
Wow, nice looking Camaro!
Thanks for the advice but this vibration occurs as I'm sitting at a stop with the car idling in gear. It's a wierd harmonic vibration that only occurs after moderate to hard braking. If I ease to a stop it doesn't happen. Any other ideas?
Thanks.
Old Apr 21, 2003 | 08:41 AM
Max's Avatar
Max
Any other ideas?
Old Apr 21, 2003 | 09:04 AM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Check and make sure your calipers aren't sticking. make sure the sliders are easy to move and allow the caliper to uncompress. I'd check lateral runout on the rotor if possible and check for glazed (blueish colored) areas which indicate high heat (or sticking caliper). Also check the tierod ends. The knuckles in these are notorious for getting loose and sloppy. Make sure there is no play at either side with the car jacked up. If there is see what is allowing movement of the wheel and take care of it.
maroe624
Apr 16, 2017 08:29 AM
db057
Aug 22, 2015 08:17 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
novaderrik
Aug 10, 2015 12:44 PM
