Baer Brakes
Old Apr 19, 2003 | 09:36 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Baer Brakes
I have been thinking about a Bear Racing kit for the rear brakes on my 92. I want the Touring/Track set up they sell. The rear has 12 rotors and single piston calipers. Does anyone know if a 15" steel wheel will mount with those binders installed? I have 17" alloy wheels for daily driving, but have 15" rears for slicks. Anyone know? Thanks.
Old Apr 20, 2003 | 08:56 PM
ronterry's Avatar
Car: '94 Corvette
I hadn't had a chance to mess with that PDF I downloaded, but over on www.baer.com - go under Support | Templates, and select a car, and download / Print the template...
See if that helps, at worst consider this reply a bump back to the top
Ron
Old Apr 20, 2003 | 09:14 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Thanks, I'll look into that.
Old Apr 21, 2003 | 04:30 PM
Kandied91z's Avatar
well considering the touring kit (rear) is identical to the stock 91-92 disc brakes with a slightly .5"larger one piece rotor it shouldn't be too hard to test it out.
i can't fit a 15" rim over my stock brakes like your describing without taking a piece out of my caliper on the stock 11.4 disc size so i really don't think it will fit but crazier things have happened if your wheels has a good size backspacing.
good luck.
Old Apr 21, 2003 | 06:13 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Thanks for the info. I really want the Baer rear discs, and I want my 15" slicks. I guess I can't have my cake and eat too. We'll see, I'll get the template from Baer and see if it fits.
Old Apr 21, 2003 | 10:53 PM
Kandied91z's Avatar
the rear setup doesn't look any different then the stock 91-92. so no one will even notice unless you tell them.
if you want the looks like the eradispeed rotors they do have a new touring system coming out very soon that is suppose to replace the current setup. however, your wheels definately won't fit then.
good luck.
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
84 TA NV
Sep 6, 2015 08:02 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
