Spring Change
Old Apr 21, 2003 | 07:49 PM
WideOpenVTwin's Avatar
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
Spring Change
Quick question:
If I change my old stock RS springs with new stock Z28 springs (I THINK they are the same height), will I need a realignment?
Also, can I just change the front for now, or should I do the rear at the same time (money issues)
I'm concidering a pair of MOOG replacements, but the 5662's are in the 706lb-in range, which is stiffer then I want. Are there any MOOG springs in the 500lb-in range? If so, what is the part number?
Thanks!
Old Apr 21, 2003 | 11:05 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
Of course you wouldn't need an alignment for the front springs but when you install the front ones you will have to disassemble most of the front steering/suspension components and it's always a good idea to have an alignment done after that.
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
gixxer92
Sep 1, 2015 04:32 PM
johanlindgren
Aug 16, 2015 12:16 AM
