245's up front. will they rub?
Old Apr 21, 2003 | 01:13 PM
85_ZED28's Avatar
Car: '85 Z28
just as the subject says, will there be any rubbing with 245/60/15's on the front?
thanks
Old Apr 21, 2003 | 01:28 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
They shouldn't Colin.. Most Iroc's etc. with the 16" rims came factory with 245/50/16....Lots of room.
Old Apr 21, 2003 | 01:41 PM
85_ZED28's Avatar
Car: '85 Z28
lol oh ya, good call
Old Apr 21, 2003 | 01:42 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
LOL!! It's OK..I'll let you go this time..Next time it's gonna cost ya...
Old Apr 21, 2003 | 02:22 PM
82camaro's Avatar
Car: 82 camaro SC
245/60R15's are taller and will probably rub. Mine rubbed hard with 245/60/R15's, not at all with 245/45R16's I have now. You can use the 245/60R15's, just don't crank the wheel. Or use 235/60R15's.
Old Apr 21, 2003 | 02:25 PM
85_ZED28's Avatar
Car: '85 Z28
i was thinking of going with 235's in the front, gotta make a decision soon!
Old Apr 21, 2003 | 02:33 PM
jRaskell's Avatar
245/50R16 and 245/60R15 tires are virtually identical in height, less then a tenth of an inch difference. If you were rubbing with 245/50R16s then there was a problem somewhere else. These were an OEM tire size and I get no rubbing on my GTA at all. Perhaps the wrong wheel offset if you didn't go with an OEM 16 inch wheel. On third gens the offsets are different between the front and rear wheels. Rear wheels will rub if put on the front (Tire warehouse did this to me a few years ago.)
Basically the proper wheel offset is critical for properly fitting a 245 tire on your car. Whether OEM 15 inch wheels have the necessary offset for a 245/60R15 tire is the question that needs to be answered.
Old Apr 21, 2003 | 07:40 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
275-40-17 on the front of my 83TA - needed 5/16 spacers to clear the tie rod - very little rubbing - not enough to worry about.
Edit - had 235 -- 15s on there before - not rubbing at all.
Old Apr 21, 2003 | 08:36 PM
82camaro's Avatar
Car: 82 camaro SC
245/60R15's are 1 inch higher than 245/50R16's.
Old Apr 21, 2003 | 09:18 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Correct - wheels would be 26.6" and 25.6" respectively.
Old Apr 22, 2003 | 10:00 AM
jRaskell's Avatar
I stand corrected. I must have made a calculation error initially. 245/60R15s are 1 inch higher then 245/50R16s. Sorry for the misinformation earlier. And thanks for the corrections fellas.
Old Dec 12, 2003 | 11:39 PM
F-Bodeee's Avatar
Car: 1991 Pontiac Trans Am
Transmission: Borg Warner T-5
im runnin 235-60-15 on the front and they rub.....i can't make a u-turn w/o them rubbin.
Old Dec 13, 2003 | 08:26 AM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
yep, me too
Old Dec 13, 2003 | 02:36 PM
F-Bodeee's Avatar
today i cut out around where it rubs on the drivers side and i took out the little plastic piece and the wheel turns fully now
Old Dec 15, 2003 | 05:24 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
If you need to calculate the tyre diameter then the following www page is neat :
http://www.net-comber.com/tirecalc.html
Si.
Old Dec 15, 2003 | 10:34 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I'm running 275's (all around) and they don't rub at all....
MrPackstin
Oct 25, 2017 08:09 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gta_knight
Sep 23, 2015 04:59 PM
Youngs92
Sep 23, 2015 11:29 AM
corey8084
Sep 17, 2015 02:56 PM
