would rebuilding the drum system make the parking brake stronger?...
Old Apr 23, 2003 | 05:54 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
I'm talking about replacing all the springs and what not thats in there. Would that in anyway make hte parking brake engage harder? Thanks.
Old Apr 23, 2003 | 06:25 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Just as much as replacing all the crap there will improve the braking in the rear end it'll improve the holding power of the parking brake since it just uses the pads etc ...
All the parking brake does is engage the rear pads... the springs in a drum brake are return springs though... not holding springs...(just singling out what you mentioned...)
Old Apr 23, 2003 | 07:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not stronger, as such; but it will make it work more smoothly, and maybe adjust more reliably, which will help it work better even if not stronger.
Old Apr 24, 2003 | 10:03 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Take out the self adjuster and clean/lube the threads.
Old Apr 24, 2003 | 10:35 AM
ede's Avatar
ede
i'd make sure the self adjuster was working and adjust the shoes before i jumped in and started replacing all the hardwear.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
