Difference between Konis for 14-15" wheels and 16" wheels
Old Apr 24, 2003 | 12:41 AM
CaysE's Avatar
Why does Koni list two different types of shocks/struts for our cars? What are the differences between them? Mine would fall into the 14-15" category, but I plan to eventually put 17" or 18" as I get the money for them. Any insight?
Old Apr 24, 2003 | 10:38 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
I have wondered this myself.
My "GUESS" is that the strut housings are identical in size and shape- its the valving that is different. 16" rim F-bodies came with higher rate springs. The reason then for the difference is the fixed (non adjustable) compresion valving- because the rebound is adjustable.
With that stated- again I want to clarify that its just an educated guess.
Old Apr 24, 2003 | 10:46 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i would have to agree with 2.8's guess. mounting wise there should not be a diffrence, it must be in the valving.
Old Apr 25, 2003 | 12:14 AM
CaysE's Avatar
OK... so (theoretically, if your guess is correct) I should go with the 16" struts/shocks if I have Eibach Pro-Kit springs on the car?
lol.... maybe I should just call them
Old Apr 25, 2003 | 06:08 AM
Dewey316's Avatar
Car: 1990 Camaro RS
yes, if our guess is correct you would want the 16" version, because it 'Should' have more agressive valving.
but of course a call would not hurt and if you do call, please let us know what they say.
Amillionoh7
May 24, 2020 08:01 AM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kah992
Aug 19, 2015 02:55 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
