1LE Brake Converters
Old Apr 24, 2003 | 09:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm ready to bolt the adapter to the spindle. Steve Spohn recommends torquing to 85 with Loctite--I have no trouble whatsoever in following Steve's advice; however, I am curious about what others have done.
Also, what about the 137 torque value where the caliper carrier to the adapter is concerned?
JamesC
Old Apr 25, 2003 | 06:20 AM
JamesC's Avatar
tt
Old Apr 25, 2003 | 09:31 AM
bennyhonda's Avatar
Car: 1992 Camaro RS
Not sure what you are asking, but I used those same torque numbers when I installed mine.
Old Apr 25, 2003 | 07:45 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Are you worried its too much or not enough torque? Those values sound like whats in the manual.
Old Apr 25, 2003 | 08:35 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Sounds like what I did.
For ALL the torque specs and more info, look at Daniel Burke's page here:
http://ws6transam.org/1LEbrake.html
This should clear it all up for ya. Specs and stuff are about halfway down the page.
Ed
Old Apr 26, 2003 | 06:54 AM
JamesC's Avatar
I'm just curious about what people have done. Dan Burke says 89 dry or 83 with Loctite; AndyZ says 84 dry; Steve Spohn says 85 with Loctite; and Ed (if I read correctly) says 87 with Loctite. Correct me if I'm incorrect, but I don't believe the stock GM adapter to spindle bolts had the Loctite patch.
JamesC
Old Apr 26, 2003 | 07:50 AM
ebmiller88's Avatar
Right...as seen in my pic below, only the bolts that connect the caliper carrier to the GM adapter had the Loctite patch. I just put more on the other bolts, and I used lockwire on some of them also.
You can see what I did at the link in my sig, then just browse my photo albums.
Ed
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
dyeager535
Aug 28, 2015 08:10 AM
