Trailing/ Control Arms
Old Apr 26, 2003 | 07:47 PM
txhotRS's Avatar
SOLID or HOLLOW
HELP, ON SWAYBARS... the bigger diameter THE BETTER RIGHT ???, ALSO, would you recomend SOLID, or HOLLOW, thanks
Old Apr 27, 2003 | 12:06 AM
BTS88IROC's Avatar
Bigger isn't always better, if you go too big then it can be a problem. How big a sway bar you want also depends on how stiff your springs are.
Old Apr 27, 2003 | 12:39 AM
vjo90RS8's Avatar
Car: 2002 Z28
you also want to make sure you match your sway bars, dont just put a bigger bar in the front or rear, if you do one you gotta do the other. I went with the 1LE 36mm front (hollow)/24mm (solid) rear and i would recommend them to anyone.
Old Apr 27, 2003 | 01:19 AM
ronterry's Avatar
Car: '94 Corvette
I have Steve Spohn's swaybar setup. It's about 285 bucks, & comes with a 33.3375mm front &*%^% oh F-That metric crap --- it's a 1 5/16" Front & 1" Rear. Both are solid 4140 Chrome Moly steel...I dare you to find one better!!!
BTW: It comes with all the poly bushings & end links you asked earlier...
Ron
Hotrodboba400
Dec 10, 2019 07:07 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
