wheal Bearings?
Old Apr 29, 2003 | 11:23 PM
Idlehands's Avatar
Car: 1985 Trans Am
Transmission: 5 Speed
wheal Bearings?
how can you tell if you have bad wheel bearings?....i lifted the front driver wheel off the ground and shook the tire front top to bottom and it feels tight., but when i shake it side to side there seems to be lot of play. Also there is a whinning noise more noticable when making right hand turns....anyone?
Old Apr 30, 2003 | 09:38 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
Are you talking about end play? I'm currently suffering from a loose idler arm, and end play of the rotor on the spindle. Even though I've tightened the castle nuts, it seems that after a few miles of driving it, the front wheels are loose again... So, I've retired it to the garage until I get the time to straighten it out.
As far as I know, if you can rock the wheel in any direction, and you are sure that you have no play in the idler arm, tie rod, ball joints or strut assembly, the only thing left is the bearings...
See if a search turns up any specs for tightening down the bearings after a cleaning/repack...
6speedIROC
16
Mar 15, 2023 08:33 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
