can't tighten top shock mount
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I am putting in a new rear and when I go to put the nuts on the top the entire top of the shock turns. How can I best prevent this? use channellocks to grip it? They are the koni red shocks.
Chris
Chris
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
is there not a hex section on the very top of the threaded portion?? Usually you can have someone physically hold the shock until you get the nut down far enough to put a backup wrench on the top...
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Nov 16, 2015 01:13 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
