2 Quick Questions Re:- Poly Bushes
Old May 2, 2003 | 04:30 AM
Dr G's Avatar
I have Energy Suspension polyurethane bushings throughout on my 1989 GTA which were installed by the previous owner around 20K miles ago.
Should I plan on replacing these at a routine interval, or only when they perish?
How often should you lube them?
I note from the tech info on Steve Spohn's site that:-
"Polyurethane bushing manufacturers advise to never use a petroleum based grease for poly bushing lubrication. Polyurethane should only be lubricated with one specific type of grease to insure a long bushing life, and squeak-free performance. Silicone based synthetic water-proof grease, the white sticky stuff!"
Thanks for the help,
Gordon
Old May 2, 2003 | 07:03 AM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
I've had mine for over 9 years without any problems or grease. I do check them for any wear every now and then. Othewise I leave them alone and let them be. If you hear any squeaking then by all means go with the advice you got and grease up
Old May 2, 2003 | 07:13 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
poly bushings should out last the car LOL.
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
NBrehm
Aug 5, 2015 07:57 PM
