rim change alignment
Old May 4, 2003 | 11:19 AM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
i know this may sound like a stupid question, but if i change the rims on my firebird to a different set, will i need to get my front end re-aligned? or can i just jack it up and change it without any other modding?
Old May 4, 2003 | 12:08 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
you would probably be fine without it,
but i am **** like that, i have an alignment done everytime i put on new tires.
Old May 5, 2003 | 06:44 PM
Kandied91z's Avatar
only if the size and overal specs are equal. change in diameter in anyway and you should get them aligned.
Old May 5, 2003 | 09:19 PM
MikeS's Avatar
Kandied,
My gut feeling is that it would be fine to just go for it. How come it has to be done?
Old May 5, 2003 | 11:08 PM
CrazyHawaiian's Avatar
Car: too many ...
As long as you dont change the suspension geometry, your alignment should be ok. The only reason I would goto an alignment shop in this situation is to get the new wheels balanced (if they haven't been balanced already).
Old May 6, 2003 | 02:14 AM
Kandied91z's Avatar
that's all i was saying............
you change the specs you should adjust to meet the requirements.
i know in my case i don't mind spending the 30 or so bucks it costs if i can get more life out of my 1,000+ set of tires. if you don't care and everything seems good then go with it.
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
g.l.mos
Aug 22, 2015 12:02 AM
383backinblack
Aug 15, 2015 06:36 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
