Brake rattle driving me NUTS
Old May 4, 2003 | 10:31 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Car is an 88 IROC with 4 wheel disc. The damn brakes are rattling so bad it sounds like my car is a bucket of loose nuts whenever I go over a bump. It's terrible. Is there any way to fix this? Thanks.
Old May 4, 2003 | 10:47 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
There is a spray can available at napa called "brake quiet". Spray this on the back side of your pads before you install them, being careful not to spray the pad surface.
Old May 5, 2003 | 12:49 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Make sure you bend the little ear tabs on the pads to hold them snuggly to the calipers.
Old May 10, 2003 | 12:29 AM
Fcarguy's Avatar
Car: 88 IROC, 07 Corvette, 05 Tundra
Engine: V eights
The rear pads actually have anti-rattle clips that keep them snug in the caliper. They probably came out. This happened to me and the rears rattled like crazy. The clips are still available through GM for a couple of dollars.
Old May 10, 2003 | 02:12 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
'88 rears are iron calipers? if so, they don't have clips- the fronts do.
Warped rotors can cause the pads to float off the rotors more when pedal is not depressed and will cause more slop and rattle in the pads. Bending the tabs on the pads will work on the outer pad but the inner pad will still wobble around much and cause rattle. Have your rotors turned and generously apply the stop squeak gel tho the back of the pads.
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
mustangman65_79
Aug 8, 2015 12:07 PM
