Master Cylinder Bleeding
Old May 7, 2003 | 05:17 PM
T/A gets T&A's Avatar
I've been bleeding my brakes and had numerous problems. I won't go into it all, but I've bench bled the master cylinder twice and I still believe that there's air in there. I know that bench bleeding is the way to bleed the thing, but I have a thought: What if I parked my car on a decline so that the master cylinder was level? Would it still be necessary to bench bleed the cylinder, or would parking on a hill, opening the cover, and operating the system a number of times work? What'cha all think?
Old May 8, 2003 | 05:40 AM
ede's Avatar
ede
bench bleed it, if anything open the bleeder screws and let it gravity bleed the system. i have a phenoix injector system ( along with a brake pedal jack), little pricy but now i wish i'd bought it years ago. nother better or easier for bleeding hydrolic systems.
Old May 8, 2003 | 02:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've got the phoenix injector, too... http://www.brakebleeder.com ... I bought the V12 w/red case and smart pak. The video that came with it is priceless! It shows you exactly how air gets trapped in the GM quick-take-up master cylinder.
Bleeding those things is a complete bitch. Remember to allow 30 seconds between strokes of the m/c piston to allow the quick-take-up valve to fill with fluid. Also, be careful if using the bleed kit that comes with a rebuilt m/c. Chances are the plastic fittings they give you aren't metric, and don't fit tightly into the m/c ports, so you'll be sucking air.
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
