What The !!!!!!!!
Old May 9, 2003 | 08:51 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
What The !!!!!!!!
Okay i was looking at my rear springs and where they sit in the perch is there saposed to be rubber isolaters?or is the spring it self just saposed to be on the perch metal to metal?
Also i need subframe connectors and was wondering which ones would fit the best and if you could post pictures of under the car because im going to go with a dual exhaust set up.
THANK YOU FOR YOUR TIME
Old May 9, 2003 | 10:37 PM
aklaim's Avatar
Say hello to my little friend......
Old May 10, 2003 | 02:11 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Don't know, and I can't delete this post. Sorry.
Old May 10, 2003 | 02:18 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
The axle side of the spring is metal on metal. The top or "can"should have a rubber isolater above the spring and the chassis.
