help, brakes making weird noise
Old May 21, 2003 | 01:10 AM
duke a's Avatar
when my car has been sitting for a couple of hours, you crank it up and go, the brakes start squealing. until you hit the brakes a couple of times then it eventually goes away. what could this be???? i know that nothing has ever been done to the brakes, maybe need new pads???? the car has about 59k miles on it.
Old May 21, 2003 | 07:35 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Assuming you have disc brakes all around, the problem is most likely moisture or some other foreign substance on your brake surfaces. Worn or not properly installed brake pads can also squeal.
No matter what, I'd take a close look at the pads/rotors anyway since it seems like a good time to service them.
Old May 21, 2003 | 11:21 PM
duke a's Avatar
yeah, i dont know if it matters, but it got a lot worse today. no matter what i did, except hitting the brakes, would make it stop squealing. quess i know what i will be doing tommorrow.
Old May 22, 2003 | 03:40 PM
duke a's Avatar
well its official. my pads were shot to hell. there was no pads. thats a relief. car stoppy alot better.
Old May 22, 2003 | 05:05 PM
(BR)G-Machine's Avatar
Ya... was going to say. Pads are built in with a wear indicator that squeels when moderate pressure is applied to the rotor. So if you hear that at the next red light, tell the person they need new pads.
Old May 23, 2003 | 01:39 AM
duke a's Avatar
i think that i had wore past that. they were the original pads that were on the car. had 59k on them. i just bought the car. thanks though.
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
novaderrik
Aug 10, 2015 12:44 PM
BrianI
Aug 9, 2015 11:52 AM
