Weld on or Bolt On SFC's????
Old May 22, 2003 | 07:14 AM
MX265
Guest
Posts: n/a
Weld-On or Bolt-On SFC's???? I am thinking about the bolt on as there appears to be a little less work involved. Is there a huge difference between the two? Any input is appreciated.
Thanks,
Andy
Old May 22, 2003 | 07:54 AM
MdFormula350's Avatar
I say weld in ones, i didnt even like the idea of drilling holes.
Old May 22, 2003 | 07:59 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
if you go bolt in, bolt them in, then have them welded. it will work out just fine like that, the biggest problem with bolt ins, is that over time the bolt holes elongate.
i would say whatever you get, get them welded up.
Old May 22, 2003 | 08:04 AM
MX265
Guest
Posts: n/a
Thanks for the input. I have a 70 AMP Stick (ARC) welder. Would this be good enough?
Old May 22, 2003 | 11:33 AM
i believe so, my grandfather used his stick welded to do mine, we were moving the **** to adjust amps inbetween 50 and 80 so u should be ok..
Old May 22, 2003 | 03:53 PM
ronterry's Avatar
Car: '94 Corvette
I used a 110V flux wire feed without any problem. (I think mine is rated at 80amps set to high)
I have 2 sets of rino ramps that I set the car on for the job.
Ron
Old May 23, 2003 | 06:27 AM
MX265
Guest
Posts: n/a
Thanks for the input. I think I see a set of Jeg's SFC's in my near future.
Andy
F-body driver
Mar 6, 2023 11:44 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
