brakes won't adjust
Old May 21, 2003 | 10:10 AM
ATOVETTE's Avatar
brakes won't adjust
Hey Guys
I have a problem with my brakes.My 86 camaro was due for front pads.I installed them,bled them,et. But now they go a little further to the floor than before. There's a hissing sound when the brake pedal is pushed (only first pump)in-louder in the inside.I even bled the back brakes hoping it would help-bled the front again-looks good. There is no loss of fluid-you just have to pump them up a few times for a good pedal each time. I I watch the master cylinder(plastic)there is a lot of activity when the pedal is pushed_each time. much air bubbling inside. I am at a loss.Any help out there???I'm due for inspection this mont and I'm sure there's a guy(gal)who would love to put a reject sticker on her when they here the hissing sound. thanks joe
Old May 21, 2003 | 10:19 AM
ede's Avatar
ede
sounds like you have an internal leak in the system, likely the MC is bad.
Old May 21, 2003 | 11:20 AM
ATOVETTE's Avatar
EDE
sURE SOUNDS LIKE IT BUT IT DIDN'T DO IT BEFORE i PUT THE NEW PADS ON.wHEN I PUSHED THE PISTON IN WITH A C-CLAMP,(IT LOOKED AS IF IT WAS NEVER IN).IT HESITATED AT FIRST THEN WENT IN EASILY. JOE
Old May 22, 2003 | 12:01 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: brakes won't adjust
Just curious... you said:
Originally posted by ATOVETTE
Hey Guys
I have a problem with my brakes.My 86 camaro was due for front pads.I installed them,bled them,et. But now they go...
Do you mean you changed the pads, and bled the system, and THEN noticed the problem? I wonder if you introduced air somehow into the master cylinder. With a front pad change, you don't need to bleed anything. You'd only need to bleed the system if you changed a caliper or brake hose or etc.
Getting air into our master cylinders is a complete bitch; air has a million ways to get trapped in there.
Old May 22, 2003 | 09:29 AM
ATOVETTE's Avatar
tomp
I bled the brakes because the pedal was spongy and I heard the fairly loud sucking sound . I figured air must be trapped somewhere. No dice.
joe
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
