not sitting right
Old May 21, 2003 | 06:55 PM
DreamState21x's Avatar
not sitting right
Ok, I posted this before and recieved no help so im trying again.. I have a 1988 T/A which In have put the eibach pro kit on(also changed shocks and struts at same time) They have been on the car for about a year, at first there wasn't much of a difference but they sit good now, the only thing is that the passenger side rear sits 1/2inch higher than the whole driver side and the passenger front sits about a 1/4 inch higher than the driver side(fron and back driver side are the same height).. Anyone have any ideas as to why..? I will take some pics when I get home and use a measuring tape to show you.. Thanks everyone...
Old May 21, 2003 | 07:41 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
only explanations are a taller spring than the rest or binding in your suspension. Was the car ever wrecked? maybe something is bent.
Old May 21, 2003 | 11:53 PM
springs
springs were all the same size and no it has never been wrecked..
Old May 22, 2003 | 12:43 AM
Kandied91z's Avatar
are they spun correctly? in otherwords are the tops of the coil pointing in the right or at least similar direction? how you have the spring sitting can determine the drop amount as well as the even-ness.
what about the isolators( rubber insulators) are you using them and are they new?
and lastly i know this is a bit obvious but you don't have anything heavy on one side over another keeping it uneven do you?
if all things are equal and the car body/frame is straight then there shouldn't be any problems......not to say that there isn't some defect in the spring rate that could cause the problem but i doubt it.
Old May 22, 2003 | 05:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Indexed correctly?
JamesC
Old May 22, 2003 | 11:12 AM
cool
Thanks for the suggestions, I will check everything...
Linson
Oct 24, 2025 02:00 PM
RS Reaper
Oct 17, 2018 07:52 PM
jrdturbo
Mar 31, 2016 02:58 PM
David Frans
Oct 31, 2015 08:12 PM
mfp189
Sep 27, 2015 09:25 AM
