IROC can't even lock the wheels...
Old May 26, 2003 | 08:15 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
This is in regards to the '89 IROC in the sig...
I posted back here a few weeks ago with some pictures of my rear rotors. Basically, I had new rear rotors and pads, but the rotors had rusted because of rain (which is to be expected). What I did not expect was for much of the rust to still be there after weeks of driving--especially on the inner-most portion of the rotor contact surfaces.
Trying to fix this problem, I ended up rebuilding the rear calipers (PBR calipers). I rebuilt them both with AC Delco kits. After I rebuilt them, I didn't really notice any difference in the braking power. And the rear rotors are still rusted in the same regions. Plus, if I have the emergency brake engaged with the transmission in gear and the engine idling, the car still moves.
Under normal driving conditions, the car stops fine, but it seems like I have to shove the brake pedal in more than I should have to--like halfway in. And, once the car is stopped, I can still push in the brake a lot.
I have bled the brakes at all tires. I don't know if I'm dealing with an issue with just the rear brakes not working or what. But these brakes are definately not what I thought they would be. I come from driving an '88 Camaro SC (see sig) with rear drums, and the brakes on that car feel much better than on my IROC. I thought 4-disc brakes were supposed to stop better.
Any ideas as to what I should be checking?
Old May 26, 2003 | 09:11 PM
Shagwell's Avatar
Car: projects.......
This is a much heated topic. There is another posting on here about the proportioning valve mod. It has to do w/ this problem. Basically, w/ a disc set-up, GM didn't change the proportioning valve, and the rear brakes do not have enough pressure. Think of it this way, how much fluid would it take to fill a wheel cylinder vs. how much it would take to fill the back side of a caliper piston. There are a lot of different fixes, the best probably being to put a plug in the front of the prop. vavle, (rear brakes) and install an aftermarket in-line prop. vavle. I personally have 3 small machinist washers behind the spring in my proprtioning vavle.
later, justin...
Old May 26, 2003 | 10:44 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
i to have this prob on my 89 iroc with 9 bolt and pbr disks, but it does not rust up, they just dont work, i think the pads are glazed because if the e brake is pulled all the way it is only about half way up. make sure your pads are not glazed and the e brake is adjusted right.
keep us posted.
thanks
anthony
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
